Dodge Challenger 2019 Active damping module VIN change
I replaced Active damping module from other car, everything ok except i get VIN mismatch error.
I need some help / tips on how i can do a VIN change in this module, maybe it possible using mopar online J2534 aftermarket or editing eeprom data
(03-16-2023, 11:54 AM)aremigij Wrote: Hello,
the easiest option for you is to try looking at the desired function in AlfaOBD. Or use witech online or CDA6.
Thanks given by: aremigij
Allfaobd 2.3.5 cannot connect to suspension module. After activating i try 2.3.7 version
Latest alfaobd cannot connect to suspension ECU to Sad
I tried Alfa obd as well no luck errors out. I tried to program cda6 also no luck. They have a prompt for vin reset. Just yields a response of “negative not allowed by ecu” tried Autel im608 no dice as well. I’m also in the same boat searching for an alternative.
(03-23-2023, 10:41 AM)Start2finishautomotive Wrote: I tried Alfa obd as well no luck errors out. I tried to program cda6 also no luck. They have a prompt for vin reset. Just yields a response of “negative not allowed by ecu” tried Autel im608 no dice as well. I’m also in the same boat searching for an alternative.
It looks like j2534 or eeprom is left. I'm afraid that after buying a subscription to programming mopar online, it may also fail, since the module is already used. I will try to open the module and read the eeprom
Update Cda6 was able to work. Go to the left corner to files and click on a different file. Keep opening new windows and trying the vin write function till the right file works and it will write.
(04-05-2023, 08:14 AM)do you need help or solve yet?Start2finishautomotive Wrote: Update Cda6 was able to work. Go to the left corner to files and click on a different file. Keep opening new windows and trying the vin write function till the right file works and it will write.
(04-05-2023, 08:14 AM)Start2finishautomotive Wrote: Update Cda6 was able to work. Go to the left corner to files and click on a different file. Keep opening new windows and trying the vin write function till the right file works and it will write.
hi i tried this method but it did not work for me. the write function doesnt pop up at all for the asdm ecu. not sure if im doing it right. the files you mention there is like 10 different asdm module file?
06-11-2026, 08:22 PM
