Dodge ecm reprogram
Have what I think is bricked pcm.  Need to re flash to test, does anyone know which programs I need to do?
Ummm no, cause not enough info posted....
How did u 'brick' it? Is it completely dead or still responds via diag?
What kind of ECU is it, manufacturer, model, part number?
Hit 'Thanks' and '+Rep' if I helped plzFing32
Gpec2a unlocked
Use KTag or another boot level tool
Use Ktag Trasdata Bitbox
Hello, you can try Chrysler J2534 Flash.
Regards.
;o)
try CDA as well
Umm guys, you can't flash nothing by OBD if ECU no longer boots due to bad CS...
https://m.youtube.com/watch?v=0UBYMtzl8K...p=2AEOkAIB
https://www.tiktok.com/t/ZTYAhLWfX/
Full unlock for HP tuners.   How to read the hex file, what line to edit,  what to edit it to, and how to re write to make it unlocked for hp tuners.
You can also send them in to us and we will unlock them for $100
JCLLC 712.204.3955
DJ @ JCLLC712   tiktok- JCLLC712
