22
Thanks Given: 423
Thanks Received: 62 (40 Posts)
193
37
Hello friends.
Can someone check if my file is ok?
I have egr off, dpf off and dtc P0670 off.
The car is fine but in 4 and 5 speed, sometimes it has limp mode without dtc.
I do not know what else to try, empty downpipe, disconnected sensors.
863
Thanks Given: 351
Thanks Received: 3177 (2101 Posts)
5,308
29
file is wrong modified.why you touch turbo maps for ? and sensors is not emulated in your file
22
Thanks Given: 423
193
37
I used ads and a file I had to fix myself. Finally it seems that I have broken maf. At idle I have 500mg / hub and at 3500 I have 400mg. Could you correct my file?
150
Thanks Given: 193
Thanks Received: 643 (459 Posts)
1,332
33
File is very bad.
What is 0ED394?
Is an ADS work, that is a swiftec work, copy and paste on wrong address.
22
Thanks Given: 423
193
37
Yes, it's an ads job.
Can someone make a good file for me?
1,143
Thanks Given: 397
Thanks Received: 2238 (1070 Posts)
3,378
82
(07-04-2019, 06:14 PM)alejandrobr1995 Wrote: Yes, it's an ads job.
Here Tested DPF OFF (not ads)
Chiptuning DynoTested
File services - DPF/EGR/DTC Exc
PCR2.1 Full Clone - Edc17 Full clone
/t.me/Edc17tricore
