Dyno Testing Course | Run Repeatable Tests and Read Dyno Graphs
[Image: attachment.php?aid=794863]
Dyno Testing and Dyno Graph Analysis Course
Dyno setup · power and torque curves · correction standards · comparing runs
Learn to run a clean dyno test and read the graph for what it really says
View the Course  →
Hi all,
Schiller Tuning here. We build files every day, and we also teach the skills behind this work. Today's thread is about one that gets less attention than it deserves: dyno testing. Our Dyno Testing and Dyno Graph Analysis Course is about two things — running a test you can repeat, and reading the result without fooling yourself.
A dyno graph is only useful if the run behind it was done properly. Two runs on the same car can look very different if the warm-up, the conditions or the correction standard changed, and that is where many arguments about "gains" start. The course is built to help you avoid that.
What You Will Learn
  • Before the run — setup, warm-up and keeping conditions repeatable so one run can be compared with the next
  • Reading the graph — what the power and torque curves show and what shapes them. For the bigger picture of where a dyno fits, see our guide on Dyno Tuning vs Road Tuning vs OBD Remap
  • Correction — why different correction standards change the numbers, and why two graphs are not always comparable
  • Comparing runs — telling a real gain from normal run-to-run noise
How It Fits Next to the Other Courses
Most of our courses are about the file itself: reading it, finding the maps and changing them in WinOLS. The dyno course is about checking the result. It does not replace file work, it sits beside it. A tuner who can edit a map and also measure the effect honestly makes better decisions.
It also pairs well with logging. If you want to see what the engine is doing during a run, not only the final curve, the ECU Datalogging Training Course is the natural partner.
Want to measure your work properly? See the Dyno Testing Course.
Who It Is For
  • Tuners who edit files and want a reliable way to check the result
  • Workshop owners who run or plan to run a dyno and want consistent test habits
  • Enthusiasts who look at dyno graphs online and want to understand what they are seeing
If you want to see what students go on to build, our Student Success Stories page collects real ECU projects.
Where to Go Next
Prefer We Build the File Instead?
Not everyone wants to learn the software, and that is fine. See all our ECU tuning file services and prices and send us the job.
Run Better Dyno Tests
Repeatable runs, honest numbers and clear comparisons — the Dyno Testing and Dyno Graph Analysis Course covers it from setup to the final graph.
schiller-tuning.com/ecu-tuning-course  →
Questions about the course or where to start? Reply in this thread or send me a PM.
Note: ECU tuning and dyno testing carry real risks for the vehicle and the people around it. The course teaches the testing and analysis; how a vehicle and any modified file are used is the owner's and tuner's responsibility, and modifications can affect road legality, type approval and insurance, so always check the rules in your country. Schiller Tuning is an independent training provider.
