  • 5 Vote(s) - 3.8 Average
E90 - 320d - ECU Anti-tune?
In this car described below, I received a notice that the ECU could be equipped with anti-tune. Does anyone know if Stage 1 is safe?
I use KESS 7,020 for OBD.
I leave here the original file if it helps in checking anti-tune.
BMW E90 320d
Year: 2010
ECU: EDC17CP02
BMW_320D_177Kv.zip
File Type: .zip
Downloaded: 13 times
Miguel Silva, 41
post the bosch sw number and ill tell you
cba to download file and look
maybe a free tune is not good, and a good tune is not free Kolo
Thanks given by: miguelsilv6
#3
1037501613 is tuning protected , only original tools for obd
#4
Use this file and after remap you can also write with kess clone 5017 protocol 215 is ok for write no need bdm for this 653653
[Image: item2.jpg]
#5
(07-13-2018, 01:59 AM)8ball Wrote: post the bosch sw number and ill tell you
HW: 08506438
Ver. HW: 0281016110
SW: 1037501613
(07-13-2018, 02:13 AM)@[email protected] Wrote: 1037501613 is tuning protected , only original tools for obd
I read with KESS 5.017 (Red Clone) for OBD.
With this tool is not possible?
Miguel Silva, 41
for bmw edc17cp02 obd read and write can be very good and with fgtech clone without problem
but if you have problem with write in 100% galletto will tell you ignition let stay on and write ori file
but kess nothing is telling and write is succes and after you won't start the car
Remap/DPF/EGR/FLAPS/DTC...
File Service 24/7
Database for original ecu files
Damos map packs!
#7
Just Tricore , its very quick to open BMW ecu
#8
Too much risk for OBD tuning, easy too open and to read in bootmode. It´s not EDC17C41...
#9
(07-13-2018, 01:18 AM)miguelsilv6 Wrote: Hello,
M8, kess 7.020??? genuine kess works perfect in those ecus, but for max safety should work with boot mode...
Regards.
Chiptuning services ,custom remaps, inmo off, egr , dpf, lambda, speed limits, dtc´s ,etc.
Worldwide assistance.
All brands, All vehicles, All files.
Fing32
Thanks given by: miguelsilv6 , norman1967
VW Need old VW T4 Tune MSA ecu (2 chip) JU57FL1P 0 48 Yesterday, 11:49 PM
Last Post: JU57FL1P
BMW BMW e90 318i n46 need bit more power if possible krug 3 111 10-08-2018, 07:21 PM
Last Post: vanos batam
BMW pop corn( hard cut ) need on BMW e91 320d 163 hp Gorcho 8 744 10-08-2018, 01:36 AM
Last Post: manu664
Fiat Anti Lag Launch Control Hard Cut 500 abarth eobdexpression 5 212 10-07-2018, 04:39 PM
Last Post: teobolo
  Opel Z20LEL LAUNCH CONTROL ANTI LAG cristi2m 7 434 10-01-2018, 12:08 AM
Last Post: cristi2m
