Hi all, is it possible if I change VIN and PIN to get the extra 50HP to my car? Engine components are exactly the same.
[email protected]
ECU swapping B14NEJ to B14NEH
03-30-2024, 05:44 PM
(03-30-2024, 12:31 PM)Razor0601 Wrote: Hi all, is it possible if I change VIN and PIN to get the extra 50HP to my car? Engine components are exactly the same.
after vin change you need to set correct sw for your car regarding original VIN
mercedes retrofit,coding,programming,AMG menu,CARPLAY
FORD (remote coding programming) help
opel Coding programming help
JLR services
JLR services
06-04-2024, 11:32 PM
So I tried to replace it with the 150HP B14NEH ECU, but didn’t work. I changed VIN, PIN and Odometer with IO Terminal but I can‘t get it to work. I did ECM IMMO learn via SPS, learned clutch pedal via GDS2 and tried to config & Setup. But before the setup for the oil and learning procedure SPS says no connection to ECU. Car starts but with reduced power.
I tried also the same with the exact same ECM from a donor Car. Also the same with Config & Setup.
What can I do to get it working?
