  • 20 Vote(s) - 3.1 Average
EIS PROGRAMMING DON'T WORK NEED HELP
HI EVERYONE
I NEED SOME HELP
I HAVE A 2009 Mercedes-Benz C300 4Matic WITH A BAD EIS
I GUT A NEW EIS FROM THE MERCEDES DEALER WITH A NEW SHOP KEY
AND I REPLACE IT
I FOLLOWED THE INSTRUCTION ON THE STAR DIAGNOSTIC AND IT SHOWED ME THAT THE PROGRAM HAS COMPLETE
I TRIED TO START THE CAR BUT ITS DON'T START
I NEED SOME HELP
IM NEW WITH MB AND THIS IS THE FIRST ONE I'M CHANGING THE EIS
I WILL PAY FOR SOME INSTRUCTION OVER THE PHONE- OR TEAM VIEWER SUPPORT
BUT NEED THIS DONE ASAP
THE CUSTOMER NEED THE CAR VERY BED
THANKS IN ADVANCE
AND HAVE A GREAT DAY Fing20
Handshake
have you ignition?
on w204, 90% esl damage
Thanks given by: alexjx , massrec , bawarek , daxxer , Rocinante , craig coopen
(11-15-2016, 03:39 PM)mb_port Wrote: have you ignition?
this.
also, are you sure the owner did not changed to aftermarket.modded EIS where the data is not matching with the ones you getting from dealer?
Thanks given by: massrec , KEEN
yes i changed the ignition how do i know if its the esl ? 58
Handshake
Are you using SDS? If you are, look under the control units and see if the EIS and ESL are activated and personalized to the car.
Mercedes Benz DAS & Xentry 2011
i did it this way:
with EVERYTHING EIS/ESL belonging to car plugged in.
get a key, any DAS3 key from another car and insert into EIS.
If eis is working fine, it will shows "key does not belong to car" error in dash. Then its a faulty ESL.
If it shows nothing, the EIS is gone.
hi friend
Why not first diagnose the vehicle with diagnostic star
To see which error code to help?
Depending on the type of error code we can determine the problem?
