  • 14 Vote(s) - 2.64 Average
EPC 02.2016 Error starting the EPC application
i installed ewanet and finished installation verry well. I updated Database for WIS and works verry good. When i start the EPC application it gives me Error attached in the picture and did not open EPC. I installed Ewanet on a Windows7 64bit and use Xentry 05.2016. Can anyone help me to fix this problem.
Thank you for help.
(07-24-2016, 05:18 AM)anonimo Wrote: Hello,
Thank you for help.
Try with an older Java version if you have not already done so, to me it seemed Java v7.45
Thanks given by: anonimo
sorry, but when i change the jawa is it not a problem for the Xentry Version? Nothing happens to Xentry when i change Jawa or i damge maybe the Xentry?
the jawa 7 45 version dont works for me. it is the same error.
Instead localhost, try http://127.0.0.1:9000 sometimes it has error with some dns named.
Thanks given by: Rocinante
(07-24-2016, 01:53 PM)Aless91 Wrote: Instead localhost, try http://127.0.0.1:9000 sometimes it has error with some dns named.
How to change it? thank you
Just use the link..
Ok thank you. i will check it now. best regards
dont works for me. it is another problem. i tried it but do not work for me.
I tried and tried and dont found solution. please help. thank you
this solution dont works for me.
