Easydiag Bluetooth problem, I will PAY for the help!
Hi mate,
yes but what component is getting hot (only you can find it out, nobody else can do that for you) ^^.
R.
If my answer helps you please Thanks + Rep
Thanks given by: zicimici
11
SOLVED, at least for now.
Drilled hole, installed on top of the casing small 40x40x10mm 12v DC fan, glued properly.
Soldered the fan wires to the obd connector.
On the bottom I have drilled another 25mm hole so the fan can suck air.
Tested on the car with live data for 40+ minutes, back and forth....working like a charm.
Thank you guys for your time, I will leave thanks and rep for it Smile
Thanks given by: miroslav , Ricky_25
12
Nice mod, but I think best solution is to buy a new device
Thank you for sharing your solution.
R.
1 hour ago
10 hours ago
KIA
07-31-2020, 08:15 PM
