I have a corsa d and i need to.adapt the clutch but i dont have active the special function or the programming in easytronic list in opcom...why? I have installed 2 3 opcom.version but nothing
[email protected]
Easytronic problem opcom corsa d
04-13-2025, 01:01 PM
Maybe it wasn't developed in that versions you tried.
But I cannot confirme or not if the latest version of OP-COM has this function developed. I need a car to check it.
You can check choosing Astra H Easytronic.
But in the past I used only Tech2 or Tech2win for this job in Corsa D. Need "Security Access"
Good luck
Good luck
Reverse Engineering OP-COM Rev. D+, OP-COM Rev. E+. OP-COM Professional, OP-COM Advanced, TECH2, GM MDI, Ford VCM2, Toyota Mongoose Pro2, AVDI, Multiecuscan 6-in-1 Adapter.
