0
Thanks Given: 20
Thanks Received: 5 (3 Posts)
24
Would anyone be able to assist with resetting fault code adblue in control unit?
Vin : WD3PE8CC1D5785250
Control unit : CR60NFZ
Part number : 6429011100
Control unit software : 642040300
642021502
642031108
Check Digit [1] : 07-BE-0F-1D
System number : Openshell
Thanks!
0
Thanks Given: 20
24
So I have been able to get more starts on the van and force a regen, but I still have limited starts. Vedimao shows two permanent codes, P20EE and P204F. The DPF was removed and cleaned, and every other part of the emissions system has been replaced, including the NOX sensors and adblue tank. I'm stumped on how to tell the truck that it has been fixed.
82
Thanks Given: 399
Thanks Received: 434 (101 Posts)
260
14
i Had this problem before and cannot clear it , but by up date engine ecm software version on line
it clear the code
2,095
Thanks Given: 14574
6,536
46
Is the SCR and CDI control units software the latest?
Have you tried a SCR tank level teach in?
0
Thanks Given: 20
24
So my buddy took the van on a 200 mile trip Sunday. Half way the van gave 16 more starts. On the way back the limited start message disappeared. I can only assume we just needed to drive the piss out of it until it realized we repaired it.
