FCA - PCM Replaced Procedure
Hello, I have to perform a PCM replaced procedure to learn/synch the skim / write vins on a 2015+ Dodge. I have a good quality micropod II clone registered for online use with Witech 17. Is this possible? If not, can someone please point me in the right direction as to how I can accomplish this? Thanks a lot
if you can use your clone while witech software is online, yes you can perform "restore vehicle configuration" and program the car mileage into the pcm.
you need online account for this of course..
If you know how to count, then count me out.41
(03-18-2020, 09:03 AM)techamp Wrote: if you can use your clone while witech software is online, yes you can perform "restore vehicle configuration" and program the car mileage into the pcm.
Did not work... "0x42 unable to write vin, retry restore procedure".
Anyone have any suggestions? Really need some help here.
My micropod clone has firmware version 2.4 and is registered so works with witech 17.04 software and tech authority online.
Can I upgrade to Witech 2.0 and will my micropod still work online? Will I run into the same issues?
I need to get this resolved tomorrow and running out of ideas....
I think the app "alfaobd" can program the VIN and Miles.
(03-19-2020, 09:53 AM)NocAuto Wrote: I think the app "alfaobd" can program the VIN and Miles.
Tried Alfa, also could not write for "unidentified reason". The vin's all match, i just need to get the PCM to learn the skim....
do you have any launch scanner tool? easydiag will do the pcm vin and miles change.
as for the skeem learn for a used pcm is not needed as long the vin on the pcm matches the rest of the modules in the car, should work fine.
Opel
03-19-2020, 02:59 AM
Vauxhall
03-12-2020, 01:25 PM
Holden
08-02-2019, 06:24 PM
03-27-2019, 07:35 PM
