HELLO, CAN SOME OF GOOD SOULS IN THIS FORUM CAN HELP ME WITH SPEED LIMITER ON SID208 FROM FORD? IS NOT USUAL ONE, I HAVE DONE MANY TIMES THIS ECU WITH USUAL 3 SPEED LIMITER IN FILE 2 LINES AT START OF MAP SECTION AND ONE JUST AFTER TORQ LIMITATION MAPS. IN THIS CASE IS DOESNT WORK. I CHANGE SINGLE BIT SPEED LIMITER TOO NORMALLY IS SETUP ED 157KM/H BUT VAN STILL LIMITED TO 70-72MLS/ PER HOUR SO 115-117KMP. SO PLUG ONLINE FORD, PAY FOR GET TO ''CCC'' , - BSM MODULE, BUT THERE IS SPEED LIMITER ''UNLIMITED'' I ATTACHED ORIGINAL FILE, HOPE SOME ONE CAN REALLY HELP ME.
[email protected]
FORD TRANSIT CUSTOM 2.2 SID208 SPEED LIMITER
07-16-2019, 12:16 AM
please upload your mod mate so i can check it for you
Chip-tuning File Service
Cars/Trucks/Agri/Construction
07-16-2019, 12:43 AM
(07-15-2019, 11:47 PM)modperformance Wrote: HELLO, CAN SOME OF GOOD SOULS IN THIS FORUM CAN HELP ME WITH SPEED LIMITER ON SID208 FROM FORD? IS NOT USUAL ONE, I HAVE DONE MANY TIMES THIS ECU WITH USUAL 3 SPEED LIMITER IN FILE 2 LINES AT START OF MAP SECTION AND ONE JUST AFTER TORQ LIMITATION MAPS. IN THIS CASE IS DOESNT WORK. I CHANGE SINGLE BIT SPEED LIMITER TOO NORMALLY IS SETUP ED 157KM/H BUT VAN STILL LIMITED TO 70-72MLS/ PER HOUR SO 115-117KMP. SO PLUG ONLINE FORD, PAY FOR GET TO ''CCC'' , - BSM MODULE, BUT THERE IS SPEED LIMITER ''UNLIMITED'' I ATTACHED ORIGINAL FILE, HOPE SOME ONE CAN REALLY HELP ME.Try and report
07-16-2019, 01:31 AM
(07-16-2019, 12:43 AM)smik Wrote:thank you for your help, but all this changes been done all ready in this ecu. is must be something other...i tested before solution all limiter setup to 280kh/ try setup to 300km... and try setup just 160km...any way vand do goes over 112-115 kmp(07-15-2019, 11:47 PM)modperformance Wrote: HELLO, CAN SOME OF GOOD SOULS IN THIS FORUM CAN HELP ME WITH SPEED LIMITER ON SID208 FROM FORD? IS NOT USUAL ONE, I HAVE DONE MANY TIMES THIS ECU WITH USUAL 3 SPEED LIMITER IN FILE 2 LINES AT START OF MAP SECTION AND ONE JUST AFTER TORQ LIMITATION MAPS. IN THIS CASE IS DOESNT WORK. I CHANGE SINGLE BIT SPEED LIMITER TOO NORMALLY IS SETUP ED 157KM/H BUT VAN STILL LIMITED TO 70-72MLS/ PER HOUR SO 115-117KMP. SO PLUG ONLINE FORD, PAY FOR GET TO ''CCC'' , - BSM MODULE, BUT THERE IS SPEED LIMITER ''UNLIMITED'' I ATTACHED ORIGINAL FILE, HOPE SOME ONE CAN REALLY HELP ME.Try and report
07-17-2019, 02:39 AM
(This post was last modified: 07-17-2019, 02:44 AM by modperformance.)
(07-16-2019, 02:22 PM)hendriksjohan Wrote: Here VMAX off 100% workingi just comapre your chnages with our stock file, yes, there is speed limiter, but we change it too, and van still limited 120km/70mph speed
Pass by pm
(07-16-2019, 01:30 PM)keytech Wrote: you need to download ccc in bcm and changei done ccc in bcu check via online fjds, and there is no speed limiter regarding ford
Try my solutuion pass pm
07-17-2019, 05:44 PM
(07-17-2019, 02:39 AM)modperformance Wrote:(07-16-2019, 02:22 PM)hendriksjohan Wrote: Here VMAX off 100% workingi just comapre your chnages with our stock file, yes, there is speed limiter, but we change it too, and van still limited 120km/70mph speed
Pass by pm
Does the car have the eco button?
