  • 11 Vote(s) - 3.55 Average
FRM Modules Fixing
172
(02-06-2024, 02:47 PM)Tabaluga Wrote: Hi, does anybody have dump for FRM3
E89 E9x LED XE
6135 9241006 01
9241013
Regards
i have it, why you need it?
Don't PM me for SW keys, FRM repairs, Licences, radio codes or similar, you will not get any answer...
Hi all,
I have tried to repair this FRM file but im suspecting D flash is corrupted. Does anyone have a good D-Flash for this FRM3 please?
Vin - WBAPP16070NN41974
E90 FRM3 LED XE
PN - 61 35 9 249 090
thanks in advance
FRM JOHN.rar
161.8 KB
(03-04-2024, 10:39 AM)szczęśliwy WEP Wrote: Hi all,
E90 FRM3 LED XE
thanks in advance
Use this file it is compatibile with your VIN. Cary out coding after writing flash and eee.
6135 9390491.rar
14
154.25 KB
Use Thanks and REP button if I helped you..
Hello, I need a D-flash file for the following FRM3
6135 9286883.01
Sw: 164000 /HW: 11
Thanks so much
(05-03-2024, 03:16 PM)Dr-Tacho Wrote: Hello, I need a D-flash file for the following FRM3
6135 9286883.01
Sw: 164000 /HW: 11
Thanks so much
Introduce Yourself MANDATORY DO NOT SKIP
https://mhhauto.com/Thread-Introduce-You...IP--350158
Good morning,
Can you help me please?
I am having a problem with an FRM 3 box. It seems to me that it is corrupt. I cannot get any valid data in the D Flash.
Can you help me fix it?
I am attaching the DFlash and PFlash reading carried out in VVDI Prog.
Thank you so much
FRM3 61359250454901
HWEL: 002 000 000
SW: 80
WD: 40
HW:25
.zip
Dflash & Pflash 61.35-9 250 454.9.01XET512 FRM F-series ori.zip
11
278.8 KB
(05-06-2024, 06:23 PM)greg974 Wrote: Good morning,
Thank you so much
FRM3 61359250454901
HWEL: 002 000 000
SW: 80
WD: 40
HW:25
does not work for this kind of frm F series
hi
can anyone fix FRM  E9X_E8XCA_NSW
eeprom 95320
thank you
95320_E90_Ori.rar
1.12 KB
if i help you, not forget thanks&&Rep
does anyone please know what tool i can read an write a 2009 mini r56 high eks frm module it is different on the circuit board to your usual ones
its a pl3 frmII
(06-28-2024, 01:42 PM)adambirdsall Wrote: does anyone please know what tool i can read an write a 2009 mini r56 high eks frm module it is different on the circuit board to your usual ones
its a pl3 frmII
found it on vvi prog the only thing i can read is the eeprom and flash.
the part number of this module is.
r56 high eks
pl3 FMR II
s: 6135 3455701-01
sw:70040 / HW : 0B
06-12-2026, 12:19 AM
Users browsing this thread: 5 Guest(s)
