FVDI 2014 K-LINE problem...
Hi, i have problem with my FVDI crappy device..it wont work on K-line, CAN is working perfectly...
I changed all parts i read should fix the problem but it still dont working..also checked continuity from the board to the obd pin7, so cable is working ok..
Changed:
-E-L9637D
-ADG1406BRUZ
-K6 relay
do somebody know what other parts are responsabile for K-line in the board? or what resistors/diodes check for it?
THANKS A LOT
Thanks & REP if helped PLEASE...    A GIRL THAT'S JUST TRYING TO LEARN! Blush Kolo
In all software have problem k line? Mine only in certain brand so not sure is hardware problem
Did you solve the k-line problem? I have the same problem.
08-02-2020, 12:41 PM
07-23-2020, 12:43 PM
07-13-2020, 11:24 PM
07-13-2020, 06:22 PM
07-13-2020, 05:21 PM
