  • 31 Vote(s) - 3.45 Average
FVDI for Mercedes-Benz
Hi
A friend has bought and FVDI from one of the generics websites in the internet that sell FDVI interfaces. Since the day he received the interface, it never worked. After a clean install of Windows XP, follow every video/tutorials, I'm stuck in the step it tries to connect to the interface, saying "Interface not calibrated".
I've read countless threads on this forum, and on the internet, and I think this should be a clone of a clone, and probably this never going work.
Anyone get any ideas of what I should do with this ?
Hello, is it a 2015 with softdog ?
if yes then you need internet connection for it to work
it calibrates online on the fly.com server,s
if its the old 2014 version then no internet needed
Good luck
Thanks given by: KriyenKPp
(01-02-2016, 12:23 AM)RS4V8 Wrote: Hello, is it a 2015 with softdog ?
Good luck
Yes, it's a 2015 and have the softdog. I've internet connection and it can connect to the server, and says "Remaining days: 29". On the device, the green light is blinking.
I've followed some website saying how to fix this, but still, the same error.
- The interface version it is 7.0, the software from Abrites is using 6.3 on the Mercedes-Benz.
- Already updated the firmware on the device to 2.18 and 2.10, I think.
- Already updated the USB drivers with the CDM20814.
.txt
interface_not_calibrated.txt
130
58 bytes
You have to start the fwdownloader programm. Then, press update licenses. After this, it should work. Softdog should be connechtet all the time. Do not use the usb cable on softdog. You have to connect the fvdi with the other usb cable with red and black plug to the pc.
Fly company can help you over team viewer.
I've not used mine recently buy you connect to PC
In a certain order, then run software & connect to the
Car obd plug last or else you get calibration error
Look on fly website video for order of connection
To pc
Thanks given by: bawarek
Calibration error can be also wrong firmware upgrade (for clone of clone)
it can be brick if it a real fvdi ( from fly company they can maybe help you by remote or worse case send it back)
but need to be sure that your is a real one (clone)
I just bought one of these and specificly says on the description of it that it can not be updated. By that I understood that no software or firmware can be updated. Since you say you updated the firmware that could be the problem.
Best Regards
Luis
