  • 3 Vote(s) - 4.33 Average
Fiat Ducato 2.0 edc17c49 dpf-off and lambda error
please and make dpf off and remove the error related to the lambda court with the car was cut dpf but the car was kicked on white computer edc17c49 read the k-tag
WALDI_KTAG.zip
File Type: .zip
Downloaded: 5 times
(07-12-2018, 11:39 PM)crash_art Wrote: please and make dpf off and remove the error related to the lambda court with the car was cut dpf but the car was kicked on white computer edc17c49 read the k-tag
[Image: item2.jpg]
DPF = You must disconnect diff press sensor and exhaust gas temperature sensor
LAMBDA sensor disable
ChipTuning-EcoTuning-DsgTuning
DPF -ADBLUE - EGR - SCR -LAMBDA - TVA - VSA - CAT - DTC AndMore...
Skype: Crankshaft Power
Peugeot 2.0 HDI RHR- EGR and DPF off, ~170hp remap andrzejj 0 66 Today, 01:34 AM
Last Post: andrzejj
AA+MHH DPF and EGR off Service for FREE !!! dm-automotive 173 15,336 Yesterday, 10:40 PM
Last Post: tryingtobebest
  Lambda off - Mercedes w211 2003 E200 1.8 kompresor denzzel 4 135 10-13-2018, 10:38 AM
Last Post: denzzel
  Activation v2017.05 Professional DPF-EGR-Lambda-Adblue-Flap-Remover Tim1313 129 6,303 10-13-2018, 04:37 AM
Last Post: Mirnel
  Default Need dpf and egr off Mazda 6 RF7J 2007 year 2.0 143 HP 1987robson 3 108 10-13-2018, 01:11 AM
Last Post: Mirnel
