Hello, how are you? Does anyone know if it's possible to clear the message that appears on the dashboard when the ignition is turned on? "Diesel particulate filter cleaning completed"
This vehicle already had the original file installed and the DPF system reset. Even with the modified file, the same message appears when turning the key, but the vehicle doesn't show any problems...
Is it possible to clear this fault using AlfaOBD?
