  • 60 Vote(s) - 2.98 Average
FiatEcuScan 3.4.2 cracked
19
Guys try this mod for v3.4.2
This is for educational purpose only. I do not condone using this info for reverse engineering or copyright/licencing infringement
.txt
fiatecuscan3.4.2.-mod.txt
197
464 bytes
Thanks given by: igor51 , Msmax , _estima_
20
(03-04-2012, 02:04 PM)sgtoma Wrote: Guys try this mod for v3.4.2
This is not correct
0x0BBCA0 byte 06 from 39 to 3A
Did you think
0x0BBCA0 byte 05 from 39 to 3A
Yes it is byte 05 indeed. thanks for spotting it. It is the only "39" value at that offset address.
Text file amended
thanks but not working.
Thank you, FES 3.30 works perfectly with my elm!!!
I have some problem with this version but I don't know if the problem is the ELM327 cable because FES finds 2 interface 1 is VAGCOM/KKL and the other is ELM327. someone can help me??
(03-09-2012, 03:38 PM)Lello76 Wrote: I have some problem with this version but I don't know if the problem is the ELM327 cable because FES finds 2 interface 1 is VAGCOM/KKL and the other is ELM327. someone can help me??
So?
What is the problem???
FES work whit bouth of them,yust for diferent modules diferent interface.
Don't wrealy understan what is your qestion??
Hi!
Sorry for my bad english but I'm italian.
I've a problem with the crack present on this forum.
I have installed fiatecuscan 3.4.2 downloaded from www.fiatecuscan.net
The free versione works perfectly.
When I launch the cracked exe and connect to the ecu, the connession is ok.
But when i go in Parameters (F4) and check some values to view, the program disconnect.
Can you help me?
Thanks.
fastdius
(03-22-2012, 01:46 AM)fastdius Wrote: Can you help me?
Thanks.
fastdius
Simply Sir! 58
Put your hand in your pocket > Spent the HUGE AMOUNT OF 50€ > Buy your License from FES > Enjooooooooooy! 653
Best Regards! Cheer2
Thanks given by: mladen76
12-31-2019, 06:58 PM
08-15-2019, 10:15 PM
06-07-2019, 02:45 AM
AA+MHH
05-01-2019, 09:14 PM
