  • 8 Vote(s) - 4 Average
Firmware 2.21.32 scanmatic clone
91
Hi guys, so for the boards with 2 resistors around the pads, we don't connect the reset wire to the st-link right? We just pull it low to ground and disconnect once connection is successful right?
(12-02-2025, 12:40 AM)Fendt Wrote:
(10-02-2025, 11:45 PM)Bigcam Wrote: For people who have the same hardware as me. From itcardiag.... I don't know if this model is still manufactured. Here is the connection diagram. You will have to unsolder the mini USB
Cordialy
I used a piece of old cable with a micro USB connector, and no soldering was required. The repair was a success.
good job
thank you for feedback. post picture pinout usb
cordialy
being of the universe
custom made work
Hi everyone, I also have a Scanmatik J2534 pro+ clone and I want to update to version 2.21.32.
I see there are two applications, 4.6.0 and 3.4.0, which version is the most suitable ?
Thank you all.
If my post Helped you, please press Thanks + Rep. button, thank you Tup
(01-02-2026, 01:30 AM)Joao Antonio Wrote: Hi everyone, I also have a Scanmatik J2534 pro+ clone and I want to update to version 2.21.32.
Thank you all.
Both are suitable but I generally use ST-LINK Utility
If I helped you, press Thanks & reputation Rate buttons. If you don't you go on my ignore list
Thanks given by: Joao Antonio
95
(12-27-2025, 05:28 PM)peroogi Wrote: Hi guys, so for the boards with 2 resistors around the pads, we don't connect the reset wire to the st-link right? We just pull it low to ground and disconnect once connection is successful right?
working perfect with micro usb
custom made work
I don't understand, where are you plugging the micro USB to? St-link?
My scanmatik pcb are micro usb female. Ym plug micro usb male in scanmatik and wire usb câble conect st link v2
custom made work
just a quick update on reversing this.
There is a serial blacklist inside the dll.
the firmware blob is inside the dll and extractable/decryptable
the biggest roadblock is figuring out where the serial validation/checksum happens. i have some suspicion but still trying to figure out the algorithm and reversing it.
The endgoals would be to create a firmware blob extractor, and serial generator, so we can generate our own flashable firmware from any dll with a valid serial.
Thanks given by: Ricky_25 , michalez , somethin9 , LoudNoise , meiguang , paro44 , Bigcam
99
Does anyone know if this firmware can be flashed to stm32f373vct6 controller on sm2 pro clone.
AA+MHH
Yesterday, 09:08 PM
