  • 5 Vote(s) - 2.6 Average
Ford F150 - 2002 - Speedometer DEAD!
Hi Guys
Ford F150 - 2002 - in for mileage.
White Board with HC11 3E22B.
Read with Enigma, Miles read correctly and Modified.
However on plugging back into car, Speedo Dead.
Only Bulbs Light up, such as Airbag and ABS, Mileage display is also dead, and CAR does not start!
Tried editing Dump back to normal with Same thing.
I have checked the dump against a Donor and it looks okay, so maybe speedo now faulty?
Has anyone ever had this problem before?
Would really appreicate the help as this is pretty urgent.
I have attached Dump.
[Image: 20180713_004227.jpg]
[Image: 20180713_004240.jpg]
[Image: 20180713_004525.jpg]
FORDF150 - OrigRead.zip
File Type: .zip
Downloaded: 1 times
Is there fault code?
if you think you know, then you are right,
if you think you don't know,you are right!
Cheer2
(07-13-2018, 07:07 AM)cassavafortwo Wrote: Is there fault code?
Speedo wouldnt light up do doubt there would be any communication
Any idea what could of broke?
  VW Sharan 1.9 tdi year 2002 immo off geizol 1 53 Yesterday, 11:28 PM
Last Post: d1abl0
  Isuzu Dmax 2002 all key lost help HIGH TECH AUTO 1 87 10-13-2018, 09:46 PM
Last Post: ismail
Honda honda stream 2002 immo off help me pleace!!!! universal_r 0 35 10-12-2018, 12:12 PM
Last Post: universal_r
Peugeot Peugeot 406R 2002 pin code request Bagoshite 3 176 10-11-2018, 12:51 AM
Last Post: Bagoshite
  FVDI AVDI JC BSI DEAD SOLUTION dib47 62 11,463 10-08-2018, 11:51 PM
Last Post: liviu6
