26
Thanks Given: 127
Thanks Received: 101 (61 Posts)
278
55
02-26-2019, 07:39 PM
Hi everyone ,
I have a problem with a ford focus c-max 2008 1.6l , the car has I think dpf off but additif level fault comes up P1922 - 60 , I have disconnected plug from module under back seat but same problem ,
I read with galleto flash if some one can look if dpf off and remove p1922 dtc , car is on limp mode
thanks
248
Thanks Given: 336
Thanks Received: 666 (533 Posts)
1,249
32
(02-26-2019, 07:39 PM)Autolab59 Wrote: Hi everyone ,
you need reset level aditive before writing mod file after writing mod file discconect module back seat
If I helped don't forget Thanks + Reputation Wink
26
Thanks Given: 127
278
55
Hi ,
thanks for reply , I don't write anything in ecu , I received car like that , this car work well 1 year without any problem (dpf off) , now error p1922 come up ,
I will try to reset additif level and remove plug
come back
863
Thanks Given: 351
Thanks Received: 3177 (2101 Posts)
5,308
29
your file is bad read/read again.....
248
Thanks Given: 336
1,249
32
(02-26-2019, 08:19 PM)aemtuning Wrote: your file is bad read/read again.....
i prefer edc16 only bdm read and write
248
Thanks Given: 336
1,249
32
(02-26-2019, 10:10 PM)RacingMNE Wrote: read again or find ori post here, edc16 no needed bdm for tuning or egr dpf off ,just in some opel c9 needed full bdm read
ford and opel same sometime when write with OBD 2 damage configuration
26
Thanks Given: 127
278
55
08-06-2019, 05:44 PM
(This post was last modified: 08-06-2019, 05:44 PM by Autolab59.)
Hi , can some one check this file , i have always 1922 - 60 error
thanks
