Ford Focus I FL Used ecu adaption
Hello All,
i have a questions about Ford Focus 1.6 FYDB MY 2003,
ECU Visteon 1M5F-12A650-BF
Car come with internal ECU fault
, i bought other used on the scrapyard , learn keys and car run again without problem.
I tried by learning keys with IDS adapt ECU to car, to have origin VIN, like by newer models, but i cant find this function in IDS menu. So IDS now detect it as the donor car.
..in external SPI eeprom are probably stored only keys, but something like VIN is in dump not to see. So i think that VIN is stored in the MCU..
How to corectly adapt this ECU to get there correctly VIN
Thank you
PedroX5
pm my i help you
Ford Ford Focus 2014 wiring diagram need mrkulcsos 0 119 10-15-2018, 08:11 PM
Last Post: mrkulcsos
  Ford Focus Electronic steering lock Fault mrkulcsos 1 132 08-22-2018, 12:54 AM
Last Post: OmniVersatile
  Ford Focus 2.0 TDCI Duratorque engine hunt at high rpm Poptest 0 89 08-14-2018, 02:36 PM
Last Post: Poptest
  Ford focus ST 2013 Need help Moodyali80 17 649 08-09-2018, 02:44 AM
Last Post: Moodyali80
Ford Egr off edc 16c3 focus 90cv Giuseppe2016 0 72 08-01-2018, 11:12 AM
Last Post: Giuseppe2016
