Ford IDS v86 + patch
Hello. needs software fordids v86 + patch.
I searched the entire forum but all links are expired / inactive / dead ??
Can someone give you the ford ids v86 software, or an active link?
(01-20-2019, 06:16 PM)ckdiagnostik Wrote: Hello. needs software fordids v86 + patch.
Ford IDS Version 86 Native Installer and Patch V86 and Extened Programmig
Pass = Rep + Thank
FordIDS.86_PatchExtenedProgramming.rar
404
343 bytes
Microcontroller Program & Developer.
Programmer Tooling for support.
Pass = Rep + Thank
Looking to try out this softwareSmile
Look here.
https://mhhauto.com/Thread-GUIDE-HOW-TO-...S-NEW-PICS
ids text has all the versions you want.
Thanks given by: ckdiagnostik , casanova2love2
Pass = Rep + Thank
buddy mcusys, tell me what to do with patches ?? there are two files one name is IDS PATCH and the other FordExtendProgr. Are you able to tell me what to do about it or send installation instructions. I have already installed the program but I did not run it because I do not know what to do with the patch. Thank you for everything thanks to + rep
You will read and search in member post it.
Sent from my SM-N900 using Tapatalk
Pass = Rep + Thank
install ids v86 then restart computer
install v86 patch then restart computer
SCN CODING ONLINE
vag login
skype : leminhautotek
if i help pls press thanks and reputation
Thanks given by: mcusys , ckdiagnostik
IDS allows you to update ecu software if it has a later version in it's calibration directory for (I think) 60 days after installation. When this expires just run FordExtendProgr.exe on the machine that has IDS installed at it will give you another 60 days.
(01-24-2019, 08:51 AM)diagnostix Wrote: IDS allows you to update ecu software if it has a later version in it's calibration directory for (I think) 60 days after installation. When this expires just run FordExtendProgr.exe on the machine that has IDS installed at it will give you another 60 days.
ie activation of ids is for 60 days, then every 60 days I have to renew the activation using the ford file exendprog.exe. ??
can one of my colleagues still give me IDS JLR jaguar ?? any such version of the software that would be easy to install like ids ford v86 ??
Thanks given by: UKDad
Ford
05-22-2020, 10:32 PM
05-17-2020, 04:50 PM
05-14-2020, 05:35 PM
05-12-2020, 05:42 PM
05-11-2020, 07:07 PM
