  • 2 Vote(s) - 2 Average
Ford foucs Tdci p0299 fault
Hello there! I have a focus 1.6 tdci model of 2009. The car runs fine but occasionaly it will throw a p0299 fault code and will go into limp mode. I have changed injectors, leaking hoses, turbo was repaired, solenpoid changed and I am out of ideas. If I delete the p0299 fault from ecu do you think it will stop from entering limp mode? Has anyone ever done that?
What's the code description? Have you checked glow plugs?
p0299 Turbocharger/supercharger underboost condition.
Vacuum leak?
I would start from there. Most common problem is leaking engine oil on vacuum pipes behind the engine where vacuum reservoir sits or just split in vacuum pipe.
Regards
Larue
(05-30-2018, 11:51 PM)Larue Wrote: Vacuum leak?
Regards
Larue
Of course I have checked for vaccum leaks mate and there is none. No split hose nor anything else. I have also checked and crossed out variable turbo, dpf, egr valve, wastegate solenoid. I am out of ideas!
Ford
Yesterday, 02:33 PM
Ford
10-15-2019, 03:49 AM
Ford
08-05-2019, 04:13 PM
07-04-2019, 01:53 PM
