  • 2 Vote(s) - 1.5 Average
Ford ka issue
Ford
Hello mates, I open this thread because one ford ka from 2009 came to my garage with start problem, the owner talked to me tha he had trouble with the key at the past, he drove the car fine till home by when he tried to start next morning the car no start again.
I check the car with autocom tool and see históric key failure dtc at ecu
I check the car with ford ids with vcm I and cannot read all the units, there are some errors about u0001, I can’t read any unit who work with “ can a “ and “ can b “ lines, I can’t read pcm unit. The can line has 0.24 v and 64ohm
I check the car with fiat ecu scan and show transponder key problem at ecu
I check the car with focom but not read any unit
I’m going crazy with this car, I think issue is with immo but can’t coding and don’t know what to do
I resolder dashboard conector pins and mcu without succes
I check the key with zed bull and the key has data inside the transponder
Thanks in advance
Regards
Jahra
And remember thanks and reputation button.
Hello, any suggestion ?
Best Regards
Jahra
Dodge DODGE ORC Issue Roberto 2 107 02-04-2018, 08:50 AM
Last Post: joecosta
Ford Ford F-150 2016 BCM Programming Issue iHenry3 0 305 12-12-2017, 03:14 AM
Last Post: iHenry3
  Ford IDS PATS issue. KEEN 14 3,122 12-07-2017, 10:50 AM
Last Post: karl mcghee
  [FIXED] 2006 LR3 communication issue MrPhil 0 169 08-11-2017, 04:52 PM
Last Post: MrPhil
Ford EEPROM READ/WRITE ISSUE DANITO 5 1,095 11-29-2016, 06:36 AM
Last Post: joecosta
