47
Thanks Given: 201
Thanks Received: 227 (92 Posts)
385
127
Wondering if anyone can confirm that BCM can be cloned with VVDI
Looks similar too EDGE 2017 as listed on VVDI just wondering if anyone can confirm its possible?
Also is it just a simple Backup and write job or will adaptions too the dump have to be made
Thumbnail(s)
If this post helps please THANKS and REP
Kess, Ktag, Autotuner, Flex, Smart Pro, Smok, VVDI2, VVDIMB, VVDI Prog, BIM Tool, ACDP, IM608 Pro2, Jaltest
Thanks Given: 146
Thanks Received: 53 (40 Posts)
240
46
Hi!
Any one have connection pin out for Nec70F3637 on Transit BCM to clone .
Thank you
43
Thanks Given: 137
Thanks Received: 174 (46 Posts)
233
56
this is vvdi prog connetion diagram
Thumbnail(s)
Thanks given by: rtbdiagnostic , burger152 , kramnik , asid12 , bilim , tourist069 , autofault , evautos , JASP , Demarco33333 , speed133 , t72t72 , Paulekas , Stelaras , vifi-12
23
Thanks Given: 217
Thanks Received: 107 (93 Posts)
817
242
hi did you clone it i have the same bcm
23
Thanks Given: 217
817
242
hi all i clone it one year ago withoute any problem.but today i am trying cloning the same bcm and aftrer clonning bcm death ,dont know why ?
1,225
Thanks Given: 249
Thanks Received: 2238 (930 Posts)
2,448
38
(03-18-2024, 02:46 AM) partsaut Wrote: hi all i clone it one year ago withoute any problem.but today i am trying cloning the same bcm and aftrer clonning bcm death ,dont know why ?
may be different HW,used BCM can be adapted easy with IDS/FDRS
mercedes retrofit,coding,programming,AMG menu,CARPLAY
FORD (remote coding programming) help
opel Coding programming help
JLR services
23
Thanks Given: 217
817
242
but when i write back ori p flash bcm still death
