Hi, some news here ? I have the same BCM on 2017 Ranger, it's MPC5607, VVDI have pinout for it ... Can i clone it ?
Ford transit Custom/MK8 Bcm clone VVDI
11
05-20-2024, 12:41 AM
(05-20-2024, 12:16 AM)R1LEF Wrote: Hi, some news here ? I have the same BCM on 2017 Ranger, it's MPC5607, VVDI have pinout for it ... Can i clone it ?
online PATS and 2 keys enoph to do job by obd,no need open
mercedes retrofit,coding,programming,AMG menu,CARPLAY
FORD (remote coding programming) help
opel Coding programming help
JLR services
JLR services
12
05-20-2024, 01:18 AM
(05-20-2024, 12:41 AM)globalcartuning Wrote:(05-20-2024, 12:16 AM)R1LEF Wrote: Hi, some news here ? I have the same BCM on 2017 Ranger, it's MPC5607, VVDI have pinout for it ... Can i clone it ?
OK, but i don't have car, only old and new BCM. MPC5607 inside, just read/write dflash and that's working ?
05-20-2024, 04:37 AM
Seen many dead after clone attempt.
Always use FDRS now. New unit as cheap enough from dealer.
14
05-20-2024, 03:03 PM
Hi guys.
I attempted to clone a BCM (Body Control Module) from a 2019 Ford Transit Custom, part number JK2T-15604 (MPC5607B). It was unsuccessful.
I currently own a VVDI-Prog and XTOOL.
I am considering purchasing an OBDSTAR DC706.
Can anyone suggest an alternative tool for programming BCMs, gearboxes, etc., perhaps something with a perpetual (lifetime) subscription, suitable for the European market?
Thank you for any advice.
16
04-03-2026, 07:41 PM
(This post was last modified: 04-10-2026, 05:11 PM by simone.sinapsi.
Edit Reason: Bad translate
Sorry, I explained myself poorly due to the translator.... I have a 2019 Transit Custom, it has a BCM KK3T-15604 FAH, with a Renaissance CPU R7F7015733. Due to water damage, I replaced the BCM and cloned it with Multiprog, the areas are boot, CFLASH, DFLASH, IDCODE, OPTB_7, OPTB9 and security byte. I read everything except OPTB9 because it was unreadable on neither my BCM nor the donor one. I copied all those areas that were not identical and FF them into the donor BCM, the dashboard turns on and everything works but I don't have the keys in the BCM. I tried with various tools to realign the keys using even new transponders but nothing doing, even with an official Ford it is not possible to obtain the security code. Does anyone know if this BCM is not cloneable, if it is a limitation of Multiprog, or if the procedure to follow is different? I'd like to know if the only option is to buy it new in Via di some OTP area and wait 35 days, or if I can try something else. Thanks!
17
06-14-2026, 01:27 PM
I the same BCM and same problem, anyone have any luck cloning with VVDI?
