I installed a new engine control module in my water damaged 2022 GMC Sierra.
Programmed it seeminly OK (almost programmed, keyless go module, replaced keys, + programmed a few other modules)
It diagnoses it OK but whenever I go to perform any addional functions for example crankshaft position relearn or program fuel injector calibrations, it come up with the folowing message
REQUEST REJECTED by ENGINE CONTROL MODULE I have not only it with GDS
does anyone have any ideas of how to solve this please? Or can anyone tell me if the ECM uses different communication network to change parameters than it does to do the original programming. I figure it may well do as the programming works fine, but any of the DISPLAY DATA or other config fuctions within GDS2 always come up with the REQUEST REJECTED message
thanks in advance
thanks in advance
