  • 1 Vote(s) - 1 Average
GM DPS - Module Programming (Expert Advice Needed)
10
2014 and 2015 different loader, sw/hw
Thanks given by: Antek
11
Doesn't seem like there is SPS log with the successful session. I only see the retries from the next day.
Unless there is a log somewhere else ?
Calibrations you get from sps session. So there it was spslog.txt file.
Do you guys know if there is any way to capture the boot software in a GM ECU? I can capture all calibration files, xml file, and utility file but cannot seem to trick SPS into giving me the boot software file??? Any help in the right direction?
(02-22-2023, 08:19 PM)Speedoking518 Wrote: Do you guys know if there is any way to capture the boot software in a GM ECU? I can capture all calibration files, xml file, and utility file but cannot seem to trick SPS into giving me the boot software file??? Any help in the right direc
in some cases sps will download the boot, but rarely in my experience.  what do you need the boot from?
I need the boot file 84696727 from a 2021 GMC Sierra Denali 2500 IPC!
does it have UHS rpo?
Yes
Yes
Any other boot files from any of the 2020-2022 IPC's is also ok for I will need all of them eventually! Any Help would be amazing!!
I have some software from the 21 k2500 IPC . It may be the boot and OS. what is the hardware ID?
Cadillac
05-26-2026, 04:33 AM
05-25-2026, 03:24 AM
