  • 4 Vote(s) - 3 Average
GM GDS2 2019.5 & TIS2000 2008-03 - VMWare
Two separate virtual machines. WinXP TIS2000 with last update 2008-03 & Win7 GDS2 with Global 2019.5, Opel/Vauxhall 2019.4, Saab 2019.4, & China 2018.11.
Google drive & Mega links.
Free for all.
Make sure the GDS2 machine system time is set to 02-15-2016 or else it will show no lease!
.txt
links.txt
726
310 bytes
(08-25-2019, 01:07 PM)50Satoshi Wrote: Two separate virtual machines. WinXP TIS2000 with last update 2008-03 & Win7 GDS2 with Global 2019.5, Opel/Vauxhall 2019.4, Saab 2019.4, & China 2018.11.
Free for all.
Thanks you!
Can you install additional driver mongoose jlr to help me?
Thanks given by: motorcareworld
(08-26-2019, 07:27 AM)sonseo Wrote: Thanks you!
You can install whatever drivers you need. Follow these steps:
-Power off virtual machine
-Edit virtual machine settings
-Hard Disk (SCSI)
-Advanced
-Change from Nonpersistent to Persistent
-OK
-Power on virtual machine
-Drag tool drivers to desktop and install
-Revert Hard Disk back to Nonpersistent
-Done
Thanks given by: crez , Andywill , sonseo , auto-junior , turbo.isaac , gery0627 , Arsulo
thankyou M8!
-Hard Disk (SCSI)
-Advanced
-OK
-Done
Hi!
I have successfully started the virtual machine. However, after I changed the settings on the virtual machine, I immediately lost the Lease. I restored the same time as the original virtual machine (2016) but could not restore the lease as originally. Can you give me advice on dealing with this problem?
Thank you very much!
Gửi từ G3226 của tôi bằng cách sử dụng Tapatalk
If I helped you - please press  [Image: MDYS72v.jpg] and [Image: Pz9K2aa.jpg]  buttons!
(08-27-2019, 05:13 PM)Mr.thang025vn Wrote: I have successfully started the virtual machine.  However, after I changed the settings on the virtual machine, I immediately lost the Lease.  I restored the same time as the original virtual machine (2016) but could not restore the lease as originally.  Can you give me advice on dealing with this problem?
The system clock is being altered. System time must be 02-15-2016. VMX file must have the following in it to prevent system clock sync:
tools.syncTime = "FALSE"
time.synchronize.continue = "FALSE"
time.synchronize.restore = "FALSE"
time.synchronize.resume.disk = "FALSE"
time.synchronize.shrink = "FALSE"
time.synchronize.tools.startup = "FALSE"
time.synchronize.tools.enable = "FALSE"
time.synchronize.resume.host = "FALSE"
Thanks given by: crez , GETiT
Seems link is down for gds
Nevermind. I have it downloading. Thanks
install scanmatic2 drivers- test ok!
Could not get vmci driver version: Controlador no válido.
You have an incorrect version of driver 'vmci.sys'. Try reinstalling VMware Workstation.
Module 'DevicePowerOn' power on failed.
Failed to start the virtual machine.
Thanks given by: boogry_man
Porshe
21 minutes ago
Ford
1 hour ago
Yesterday, 07:13 PM
Yesterday, 01:46 PM
