  • 24 Vote(s) - 2.96 Average
General Motors GM LAAM 2017 - Free Download
73
(06-24-2025, 09:51 PM)micha912 Wrote: Hello from Germany. Today, due to a hard drive replacement, I had to reinstall GM EPC on my computer, on which it had previously run stably for three years. The system is Windows 10 Pro 64-bit, and I still access it via the integrated IE. The installation went smoothly. After the first start, I got a message about the license. So I started the License Manager, generated a license, and entered it – as always. If I call up ShowURL.hta, the window with the URL appears. If I click on it, a new window opens with the message: "Loading license information. Please wait." Then nothing happens. If I close the window and press LAUNCH again, I immediately get the message: There is no license for GM Global EPC (GMG). Use the License Manager. However, I have already entered a license for LAAM – that's the only one I want to use. Does anyone have any ideas? Thanks.
It seems that it is an OS issue.
Try to reinstall it on Win7.
Hi,
Thanks for the detailed explanation.
Based on what you've shared, it sounds like you're running the GM LAAM 2017 EPC, which unfortunately isn't fully compatible with Windows 10 Pro 64-bit — even if Internet Explorer still opens.
That’s likely the main reason you're stuck at "Loading license information" and seeing licensing errors, even though your license for LAAM is correctly entered.
To resolve this, you'd ideally need to:
Run the EPC on Windows 7 32-bit or Windows XP (which are known to work reliably with GM LAAM 2017), or
Use a virtual machine with one of those operating systems installed.
Hope this helps clarify the issue.
Thanks given by: Horabi , micha912
75
pm me
- ALLDATA EU/USA - HAYNES PRO - MİTHCELL PRO DEMAND - FDRS İDS LİCENSE - FORD ACCOUNT - GM SPS - FİAT EPER -
NOW ONLINE PARTS CATALOGUE AVAILABLE FOR ALL CARS
https://mhhauto.com/Thread-ONLINE-PARTS-...R-ALL-CARS
05-01-2023, 02:43 AM
