HELP with cas3+ egs edit
hello all
can someone please help me with editing  a cas3+ eeprom i need to edit the pass for the egs from the old cas to the new used cas the x6 had a damaged dme so got a used  dme cas3+ and key it starts fine but transition is blocked
need to extract the egs pass from the original cas  eeprom and edit it to the new used cas eeprom
i would appreciate any help thanks
new used LC66374_EEPROM_1910122324.rar
15
1.43 KB
originalLC66172_EEPROM_1910122252.rar
16
1.41 KB
why don't you change isn in ecu?
this cas3 is crypted you need to know isn,have working key or have ecu dump to decode it properly
New!!!Clone of med17.5.21,me17.5.24,med17.5.25,EDC17CP56,EDC17CP64 immo off/immo rebuild on VAG ecu's Modus/Clio/Megane steering column repair/virginising Merc EIS/EZS/ECU/Key generation ...and many more.
Thanks given by: KriyenKPp
(12-05-2019, 04:31 AM)Keller Wrote: why don't you change isn in ecu?
hello i have working key and i have isn for old and new dme
i dumped tha cas with mini ADCP  it has a renew option for the cas3+ but it dose not work
and with what can i change the isn in the ecu
you did not give any info about ecu ... boot read clone,manual edit of isn in boot read or with big boy toys by obd like autohex,avdi..
These are from cas3 soft and some brain
it may help a little
Desktop.rar
23
65.31 KB
Thanks given by: kihh , KriyenKPp
(12-05-2019, 07:19 PM)Stelaras Wrote: These are from cas3 soft and some brain
i did with the tool i have mini adcp but did not work it goes to tampering protection it is a x6 2010 hybrid
lol that's a bit embarrassing ...I been lazy and I put your dump in a tango without looking at it ...I can't believe they did not pick up on this yet
try this if not sorted yet
new used adopted.rar
11
1.46 KB
(12-06-2019, 05:42 AM)Keller Wrote: lol that's a bit embarrassing ...I been lazy and I put your dump in a tango without looking at it ...I can't believe they did not pick up on this yet
Hello I'll let you know
hello
sorry for the late response i tried it but i get tampering  starts and shut down
15 minutes ago
06-30-2020, 07:18 PM
06-22-2020, 01:18 AM
06-21-2020, 11:44 PM
06-20-2020, 03:25 AM
