To obtain your registration code, please reach out to [email protected]
  • 128 Vote(s) - 3.05 Average
HONDA HDS 3.012.030 TizWaz FULL Build
46
Why mate?
If you want to make it works with HIM or GNA600 or even with AVDI then use the same method that Mr. TizWaz shared and you hve a good working HDS
It is not diffrent.
Good luck
Thanks given by: vinha916 , ime-actia , Ludvi
47
(02-28-2014, 05:20 AM)Carboy Wrote: Hi Guys,
This is HDS full version 3.012.030.
This needs work to make it usable.
Hope Mr.TizWaz and other MHH members
can help with this.
mate, if you cannot make it yourself, then you need to give le login to your computer so i can do it for you.
Thanks given by: MRTHON262 , ime-actia , arturoloco
48
possible today Tizwaz? I have my pc on whole day for you.! when you will be back?
(02-28-2014, 08:15 PM)vinha916 Wrote: possible today Tizwaz? I have my pc on whole day for you.! when you will be back?
in about 6 hours i will be here most of the evening, if anyone wants help then is the time to get it.
Thanks given by: ime-actia
50
Got past the pass-code, Installed the cw rewrite and spx, took me to here
Stuck at the Honda Extension: Authorized Dealer/Independent Repair.
Both of these ask for codes etc that I don't have.
Anyone went farther than this and willing to give info
Using the 3.012.030 version
Thanks given by: TizWaz , gchinaman1
51
o.k here i have made torrent for latest 3.012.030 with ecurewite for SPX - GNA -HIM
includes install and unistall videos
you need to remove your old versions first.
Dont forget to remove the file on C:/ HN2000A < you cannot install this version if you leave it < That i think is Sleuths problem above
MHHAUTO.rar
2,350
12.91 KB
TORRENT WILL BE SLOW BECAUSE I ONLY MADE IT, PASS IT EVERYWHERE AND SEED ONCE YOU HAVE DOWNLOADED.
For X-horse Users, If HDS Request firmware update , Rename the GNAReprogramming.dll to GNAReprogramming1.dll
I ony known X-HORSE WITH 1.47/1,48 FIRMWARE AND 1.48 DRIVERS TO WORK WITH THE LATEST VERSION!!
When you install drivers, wait for connected bubblefish connection and restart the computer, when restarted, use the HDS SHORTCUT that was crated when you installed x-horse drivers.
Regards honda him....you need good one that has dual PCB.
For GNA Users - Please make Sure you have GOOD Quality GNA600 to make update or you can Brick your tools!! Anyone who purchased SUPER GNA600 < for sure that is FLY Tool and no take update , YOU Can change
BCF file for one that came with your software , so it fakes the update.
Member Sleuth Have confirmed CTC Can-Tie-Car Works good also
Password for rarfile
TizWaz-MHHAuto.com
Please press thanks if you find useful, i spent one day and a half to make this as simple as possible for the users of this forum .
Thanks given by: IheartCars , mattydr67 , Sleuth , chingon , hotwheels , baiyouxu , mkpzang1 , autorepair , oemtool , kvadratas , sparkfly , j4ru , mikuzza , mwonderchild , postman , BrianJones , Carboy , Justin24zz , ibmman , nadim malouf , ancient , fraze , JOSEPE32US , h3nd0_86 , Starmobile , wddn , sogaro , reww , sigma4506 , elitricista , ime-actia , rrador , evpowers , Boneo , gabriell , tedi_k , r66r66 , Iggie , miktek , derdud , elecauto , shintake , IrocZ89 , mamujim , mecadriano , Lands , buga37 , rayonelemos , autoelectro , esir20 , medichply , wissoaj , iluxa73 , pipb , kamaleon , premaut , decimation1 , siekierski89 , adlr , thanhtung3000 , pr0zac , lockpickfan , Tomasiukas , pjfb7800 , Sparky001 , jonixins , drako_amg , automac , sam pro , ravib82 , mrdzwiedz , Jawarens , craino , sm75 , jwth , adam4671 , dib47 , laco210 , daro_mayday , dswedine , hercaim38 , byprototype99 , gwee , jaime20 , nathansauto01 , tkinyan , scotty , haydenautoservice , aparty , mini_man , putodaserra , RobertTalker , Deortuka , Damex33 , ricardo_sx , zipoman2011 , narkeleptk , akbarkeys , superlex , Isrraelito , p9776 , smelly hole , VitzonFire , datapage , haoto , sjaak523 , zepppp , nasscristhian , dziongas , samsul_49 , electron , bargaindepot , Gringo , seli1 , teo32 , sahin45 , Taki_da , cano , suri , etronic , javachai , Andywill , WEA29 , tedi , Renedo , mohamedramli , hass42 , carol1869 , rabihfiras , urgodfather , Dimus778 , rocris , phuongnt , thanh1974 , jaguarxf5 , evgenijj , kaniajerzy , hbalazs , Blackgod , darmoyan917 , auto2000 , garagescunny , speedr , aminemestour , paulg1919 , JoeDiesel , tuanzen11 , tunhan , menaoski , ParisCY , bansly1 , alexden31 , dule14786 , trifaze , Sanmotor , sharaf , Stevieracer , raynine , coolghost , Dominduct , jvm.almere , ncmech , psihosoft , MasterFauker
52
I made it thru the Original install...Only problem is It is Independent Garage Install version ( not sure if the immo will work) It also will not allow me to massage the dealer Number. It can be changed in the registry, but after you start Program..check Dealer number.. it says not available and cannot be set in HDS Program, If you change it in the registry, it looks good,,until you start and run program, then it defaults to the 000000 Dealer number.
It does find and use the CTC interface !
Thanks given by: jaguarxf5
53
(03-05-2014, 12:01 AM)Sleuth Wrote: I made it thru the Original install...Only problem is It is Independent Garage Install version ( not sure if the immo will work) It also will not allow me to massage the dealer Number. It can be changed in the registry, but after you start Program..check Dealer number.. it says not available and cannot be set in HDS Program, If you change it in the registry, it looks good,,until you start and run program, then it defaults to the 000000 Dealer number.
DOWNLOAD THE TORRENT AND FOLLOW THE VIDEOS INSIDE.
REMOVE ALL TRACES OF YOUR OLD HDS AND INSTALL THE ONE IN THIS THREAD
Thanks given by: Sleuth , ime-actia , psihosoft
54
mkpzang1
i dont want your thanks.
go suck some patrian and the grease monkeys asshole you bum sucking scum
Dont forget to post on AP like its your own work
Thanks given by: alexG , impaler11 , ime-actia , gabriell , rude , pmaf , thanh1974 , psihosoft
11-26-2023, 04:44 AM
Toyota
11-19-2023, 09:02 AM
