14
Thanks Given: 142
Thanks Received: 121 (32 Posts)
155
40
I have a customer's 2023 grand cherokee v6 petrol engine. Vehicle was in a car accident and after that it wont crank/start
I deleted all dtc codes and did reset pcm, bcm and srs module. Did the turn signal method to try to reset the "Enhanced accident response system" but had no luck
Any advise?
0
Thanks Given: 32
Thanks Received: 7 (6 Posts)
40
17
Hello
Please send the DTC, As Will you checked A battery + terminal Maybe there is a Fuse or Shutoff Safety sensor activated after Accident.
14
Thanks Given: 142
155
40
08-24-2024, 04:44 AM
(This post was last modified: 09-03-2024, 05:54 AM by andresz28.)
Still wont start, all fuses are good, no codes on any module and I tried to bypass the starter to make the engine start and it did crank but wont start
If someone else's is having this problem. You need witech and go to special functions and reset pcm crash report
