  • 31 Vote(s) - 2.42 Average
Help! Cannot read HC11F1
19
(04-05-2014, 02:24 PM)automf Wrote: read 2 HC11F1 plcc68 just 1 hour ago using x-prog clone.
For incircuit programming:
1) give +12v (all the pins needed) and gnd to ecu
2) connect to HC11F1 using THESE x-prog schematics like in attachment (should be 7 wires)
3) MOST IMPORTANT: in xprog configuration use THE SAME OSCILLATOR FREQUENCY LIKE IN OSCILLATOR ONBOARD (4mhz,8mhz,16mhz...)
4) select of course HC11F1 in DEVICE SELECTION Wink
I had to do some tries, but this method work ALWAYS, without detaching anything.
bye
this worked with my xprog-m 5.55
(02-05-2016, 11:38 PM)stefy_hgs Wrote: After sone hours of disperation I've managed to read/write the MC68HC11F1 inside a IAW 16FM.E6 using carprog. Taught I'd share the solution.
Use the scheme in the carprog manual to connect to the chip and short pins 2/3 MODA/MODB.
Give power to ECU 12V+ PIN 26,35
GND PIN 17,34
That worked fine for me!!!
Regards!!!
I am trying to read delco multec (red/white) with carprog clone 10.1. Can u explain in detail which pins to lift and how to read?
This was a fight to read HC11F1 with carprog  Bench ECU
First i used UPA USB PIN 1 LIFTED, PIN 1,2,3 shorted to Ground  No 12V required this MCU uses 5+ (read, write first try)
Then i tried carprog 8.21 (what a fight till the end but now i read and write first try)
Used the pinout from carprog but left PIN 1,2,3 shorted to Ground,  Brown cable of A10
My MCU is HC11F1 mask 2F37E
Error even changing crystal to 16000
then i found out in carprog same HC11F1 but mask E87J i tried anyway but error
After some time multimeter i discovered the something was wrong with ground Brown cable and TX cable green one
I opened the A10 lpt socket and found that ground is in TX and TX in ground (corrected this BS)
In my mind i said it's now that i will  be able to do it
CArprog MCU HC11F1 2F37E and error again my god....
Changed to HC11F1 E87J and bingo, read and write ok
My final advise UPA is way better to read this kind of MCU
Thanks given by: Mekkatronika.Surie , sazimam
22
... sorry buy you have a solution for read this mcu to pcb without lift the pin 28 from this?
Online Chiptuning file and all solution, genuine software , tested solution
(01-14-2021, 04:33 PM)E_M_Line Wrote: ... sorry buy you have a solution for read this mcu to pcb without lift the pin 28 from this?
some chips can be read without lifting pins, but for 100% success pin should be lifted
(09-16-2020, 04:20 AM)estrika Wrote: Questa è stata una lotta per leggere HC11F1 con ECU da banco carprog
Prima ho usato UPA USB PIN 1 SOLLEVATO, PIN 1,2,3 in cortocircuito a massa No 12V richiesto questo MCU usa 5+ (leggi, scrivi prima prova)
Poi ho provato carprog 8.21 ( che lotta fino alla fine, ma ora ho letto e scritto prima prova) Ho
usato il pinout da carprog ma ho  lasciato il PIN 1,2,3 in cortocircuito a massa, cavo marrone di A10 Il
mio MCU è la maschera HC11F1 2F37E
Errore anche cambiando il cristallo a 16000
quindi io trovato in carprog stesso HC11F1 ma maschera E87J ho provato comunque ma errore
Dopo un po 'di tempo multimetro ho scoperto che qualcosa non andava con il cavo marrone e il cavo TX verde
ho aperto la presa lpt A10 e ho scoperto che la massa è in TX e TX a terra (corretto questo BS)
Nella mia mente ho detto che è ora che sarò in grado di farlo
CArprog MCU HC11F1 2F37E ed errore di nuovo mio dio ....
Cambiato in HC11F1 E87J e bingo, leggi e scrivi ok Il
mio consiglio finale UPA è molto meglio leggere questo tipo di MCU
Thanks It worked perfectly
I also found fault in carprog A10 connector.
UPA read it, just need to connect this 3 legs
(01-11-2023, 07:19 PM)misamix Wrote: UPA read it, just need to connect this 3 legs
WHIC ECU TYPE IS THIS, IS IAW8F.5T
Hello, having similar issue with VVDI PROG reading mask 2F37E. Anyone can help? used a lot of schematics, even original from vvdi but nothing works. THX
Users browsing this thread: wokounek
