  • 34 Vote(s) - 2.94 Average
Help Dpf Off Ford Kuga tdci SID 206
Hello all,
i need a working Dpf off file for SID 206
The car is a Ford Kuga 2.0 Tdci 136
Thank you
Florent
sid 206 ori.rar
96
471.75 KB
DPF OFF NO CHECKSUM
Thanks given by: techni3d
Thank you but i need the password for the file please, how do you do the file?
DPF EGR OFF
Thanks given by: techni3d , turbofan , soufix
(09-22-2015, 06:48 PM)rafal.gt Wrote: DPF EGR OFF
Hello, the car is in limp mode now, i have two errors, differential pressure too high and degraded oil, should have i to disconnect any sensor?
thank you
Sensors must be on car and connected. Try to make ash reset or dpf renew with diagnostic. If file is ok should work
Full WinOLS/Kess/Ktag/X17/CMD
Stage 1,2,3,BT, DPF+EGR+SCR+FLAPS+TVA+CAT all off+ Crackles)
[Image: f8f7fbd34fffad28bc89c9fccaa26c6f?s=80]
I can do right off egr dpf off
Disconnect Sensors ! Please Pm
Hi all,
i made ash reset but i still got the same errors. (p253f, p2455)
moreover i got this DTC's : p2463, p242f and p2455
maybe the sensor is damaged
maybe any corrections or a new 100% working file?
Thanks for help
a new 100% working file !! Go pm
Thanks given by: soufix
Yesterday, 07:22 PM
06-13-2026, 07:00 PM
