Help EGR 1.6HDI
Hello, can someone help me with an EGR problem P0406.
I would like to delete it (egr and error).
Bosch 0 281 012 620
EDC16c43
96 655 943 80
Thank you very much!
EDC16c34 PSA P66 EGR P0406.rar
12
412.27 KB
(03-01-2019, 07:17 PM)Hibvr6t Wrote: Hello, can someone help me with an EGR problem P0406.
Bosch 0 281 012 620
EDC16c43
96 655 943 80
here you go
Thanks given by: Hibvr6t
Thanks!
I test and report.
Error code P0406 is gone.
And have the plug loose from the EGR but now I have an error code P2143.
Should the plug of the egr remain?
Would someone help me?
File J.Boza works, but unfortunately with dtc P2143.
If the solution of J.Boza is good, let the connector connected
(03-02-2019, 01:35 AM)Lunacy Wrote: If the solution of J.Boza is good, let the connector connected
If I put the connector on the EGR, engine does not run well and loses power.
And a lot of smoke.
Connector loose from EGR, engine runs well but with dtc
And a lot of smoke.
Here you got, let the connector connected.
pass sent to your pm
Thanks given by: Hibvr6t , diagnostix
And a lot of smoke.
Works well so far Tup
Thanks given by: Lunacy
And a lot of smoke.
Thanks for the report friend  Tup
Thanks given by: diagnostix
Peugeot
04-11-2026, 02:57 PM
03-28-2026, 08:26 PM
Peugeot
02-11-2026, 05:43 PM
