Help Installing Euro EIS/EZS on US Sprinter W906
(06-10-2019, 08:55 PM)bhamraz Wrote: Yeah that data attached is for both original and replacement eis unit...i was seeking help to copy the same data string from original eis to replacement if someone has knowledge about it....i have no ways to read the ECU at the moment.
Hmmm, what year is the truck?
2014 Mercedes Sprinter 2500  2.1L Diesel Engine
USA
Don't reply with Thanks, press Rate button and Thanks button if I've helped  [Image: fing32.gif]
(06-06-2019, 10:53 AM)bhamraz Wrote: Hi
I am trying to install a Used Euro EIS with IR Key on a 2014 USA Sprinter with blade key.
I tried to renew the Euro EIS, installed ESL Emulator, key turns on but DASH has ------- miles and no crank no start
I tried to change SSID in EIS dump, Write it back , generate new keys with new SSID but now eis is not accepting the keys
If i write the original SSID on Euro EIS it works fine but then i can't start the sprinter as SSID is different from the one in vehicle
Can some one guide me the write direction
In short i am looking to get IR MB Key on my sprinter instead to Blade key
not posible cause diferend....blade special repeat code does not tell about what key was actually pressed when you transfer to ir.
SEEDKEYS-ECU-REPAIR-KEYS-IMMO-ORIGINAL OPTICAN-CMD-ABRITUS FULL MERCEDES-ALFA-PSA  GROUP-VW-ORIGINAL XPROG-UPA ENIGMA-MANY OTHER
if i help..press “ thanks”Plus rep''
how about this
VVDIMB_EIS_OBD_E0F99C37 - fix2.rar
372 bytes
New!!!Clone of med17.5.21,me17.5.24,med17.5.25,EDC17CP56,EDC17CP64 immo off/immo rebuild on VAG ecu's Modus/Clio/Megane steering column repair/virginising Merc EIS/EZS/ECU/Key generation ...and many more.
Thanks given by: bhamraz
14
(06-11-2019, 02:38 AM)Keller Wrote: how about this
Hey Keller
It didn't changed anything...
I guess we have to find the data which EIS and ESL and ECU Shares in common but till then
i have ordered another ESL Emulator...will check and update
Appreciate your help on it, will keep you posted
Possible that vvdi don't read part of eeprom is needed for ecu handshake ?
(06-12-2019, 10:36 AM)Keller Wrote: Possible that vvdi don't read part of eeprom is needed for ecu handshake ?
I'll be having my VVDI Prog by weekend so will try read dumps through it from both eis units
Please find attached both EEPROM DATA and FLASH DATA read directly with VVDI Prog
hope this helps
Happy Sprinter Project.rar
165.24 KB
Yesterday, 04:59 PM
08-16-2019, 02:25 PM
08-16-2019, 01:38 AM
08-14-2019, 04:35 PM
08-09-2019, 02:38 PM
