  • 5 Vote(s) - 3 Average
Help - Isuzu DMAX / DTEC 4J crank sensor wiring
Hi, I need some help with checking the wiring on a 2009 Isuzu DMAX/DTEC 3.0TDI 4J engine
Vehicle is cranking but not starting and I get a Crank Sensor fault. I replaced the sensor but still not starting.
I checked the wiring and tested on the plug for the crank sensor (see pic) on pin 1 and 3 I am getting 4.8V and pin 2 is ground
As the Cam Sensor is exactly the same I checked the wiring there as well and getting the exact same readings.
I tested for continuity from the sensor plugs and the ECM plug and there does not seem to be any break in the wire. I tested across pin 1 and 3 for continuity and there is no short in the wires.
Are the values I am getting correct???
possibly a stretched timming chain or the pick up of the cranksensor - where it picks up from the teeth are bent or 1 is bent out of place .
1: Check the connection to ground (pin 2).
Turn the ignition on. Measure the voltage on pin 2. Is it between 0 and 0.2 V?
2: Check the connectivity of pin 1.
Measure the resistance between pins 1 and B 58 (E1 Engine control unit). Is it less than 1 Ω?
3: Check the connectivity of pin 3.
Measure the resistance between pins 3 and B 37 (E1 Engine control unit). Is it less than 1 Ω?
4: Check the shielded wire.
Measure the resistance between pins 1 and B 38. Is it infinite?
5: Check the shielded wire.
Measure the resistance between pins 2 and B 38. Is it infinite?
6: Check the shielded wire.
Measure the resistance between pins 3 and B 38. Is it infinite?
Pin number Wire colour Component Pin number Wire colour
1 Yellow E1 Engine control unit B 58 Yellow
2 Blue E1 Engine control unit B 39 Blue
3 Green E1 Engine control unit B 37 Green
are you working on a 4jj1 or 4jh1
also delphi or trantron ecu
Opcom HQ Clone , GM MDI,TECH2,Bosch KTS 570,BMW K+DCAN,Launch Easydiag/XPRO3,Autoboss, Autocom/Delphi/WOW,VAS 5054A with OKI chip,Ross-Tech Vag-Com VCDS,SBB,T-300,DigiProg,Volvo DiCE,Xprog,KESS V2 V5.017,KTAG V7.020,FVDI Abrites China Clone
Pc Rep & Thanks If I Helped Pc
09-11-2019, 10:26 AM
09-03-2019, 07:41 PM
Chevrolet
08-04-2019, 05:16 PM
Vauxhall
06-22-2019, 08:39 PM
Vauxhall
06-14-2019, 12:10 PM
