[Help]Problem with Diagbox
hello..
i  have one   big problem with diagbox..
what is the problem...
i download for  here  the diagbox https://mhhauto.com/Thread-PSA-Diagbox-8...ht=diagbox
i have clean windows 7 x86.
i start to install normal  just like the instructions..
install  the first part  diagbox 7.01
all is  ok  install the diagbox auto install lexia and pp20000 all is  go..
i restart againt  i open the diagbox is finish the update..
all is go.. i go to test the problem to see if is working..
1: test is not search car frame i put   manually  is open the setting here
[Image: DiagBox-Lexia-3-PP2000-Program-New-Keys-...-307-4.jpg]
and here is stuck....
 next i go againt to install the seacon part  Diagbox 7.xx-7.57
i finish againt all  i dont have problem with  program..
i go to test againt the same problem againt...
can you help plz
(02-06-2020, 03:35 PM)AvramiService Wrote: hello..
can you help plz
You probably have a poor interface quality. Is this a Chinese clone? Have you installed other Diagbox versions before? Did you use the uninstaller to uninstall? Try when you see a window like the one in the picture, remove the USB plug from the laptop and insert it again.
Thanks for Cooperation!!! 653
I'm converting a Chinese DPA 5 to work with CNH EST.
1: i have this system
[Image: 2312933_3_b.jpg]
2: the problem i download is for here  https://mhhauto.com/Thread-PSA-Diagbox-8...ht=diagbox
3:  i have download this one and one  more the same version...
4: i  have install  so many times and the same problem..
5: i have uninstall  usb so many times..
6: if you have any link with diagbox and is work plz post here to download  and to install...
(02-06-2020, 04:14 PM)AvramiService Wrote: 1: i have this system
This is a Chinese Diagbox clone. The error does not depend on the software only on the interface that does not send the correct messages to the laptop. If you don't want to open the diagbox interface then try to unplug the usb plug from your laptop and insert it again. If you have installed this version of Diagbox several times did you use the uninstaller to uninstall the previously installed software? Do you understand what I'm writing?
On forum you have this version DiagBox on VM. It is works good.
i understand what do you tell me.
ok i go later to uninstall  the drivers for usb again and to install to see if something changes and i post here..
hi.. safari011.
if you link the link i have post is for here.. i dont now if  you tell me the same version i have but give link.. ths
(02-06-2020, 05:39 PM)AvramiService Wrote: i understand what do you tell me.
hi.. safari011.
I do not write to you to uninstall the drivers .. You just need to disconnect the usb interface plug from the laptop and connect it again if you can not enter the car driver menu ..
we cna install DIAGBOX v9.23,
if ur interested, please PM me
 AUTEL AP200 + LAUNCH X431 ACTIVATIONS FOR ALL DEVICES  |Thankyou Please Give Thanks + REP if i helped you
Thanks given by: Frenki1995
Hello all again.. I try to connect my laptop with my car but is failing again .. the programma is work go but the usb is not..
Here is photo..
Can I have one link to download the driver and the pci serial port plz
01-16-2020, 02:25 AM
12-14-2019, 12:51 AM
Author: iRik
11-24-2019, 04:31 PM
Author: iRik
10-25-2019, 08:13 PM
