Hello Everyone,
I am practicing tuning, and this is my first attempt at VAG components. I am having trouble reading EEPROM and Flash from EDC17c64 using clones of SM2 Pro and PCMFlash with clone dongles. The read files are coming out mostly empty, except some header data, and I'm trying to figure out if it's a problem with the ECU or with the clone hardware.
I do not know which car the donor ECU is from. I eventually want to use this to clone from my running Skoda Octavia Mk3.5 2.0 CRVC(Donor ECU has exact VW & Bosch part numbers and label).
I have attached ECU Label as well as reads of Password, EEPROM and Flash from donor here.
Below is my setup:
1. Used ECU from eBay: Part # 04L907309C, Bosch part # 0281 018 511
2. Stabilized 13.7v power supply(tried 14v too)
3. Scanmatik SM2 Pro clone with software v2.21.22
4. PCMFlash 1.2.0 as well as 1.2.1 with clone dongles(these worked on Delphi DCM3.7AP using OBD earlier, using GoDiag J2534)
5. GoDiag OBD Full Protocol harness(using OBD1 and OBD2 for GPT with manual power control)
6. 3 LED SM2 Boot/Bench v4 harness with On/Off/Auto switch(tried automatic as well as manual power control)
No matter which combination I used from the above components, result is always same.
ID from PCMFlash Module 50 (OBD):
Interface: Scanmatik - SM2 USB
DLL: 1.0.0.87 (built 25.11.22)
Firmware: FW:0976 HW:02 SN:A78730
Protocol: VAG: 1.6L, 2.0L TDI (EDC17C64)
Identification
Part Number: 04L907309C
SW Version: 0020
Hardware: Error 2231
ASAM: EV_ECM20TDI01104L907309C
VIN:
Reprog count: 0
ECU: ???
Completed
ID from PCMFlash Module 71:
Protocol: Bosch: MEDC17 (TC1724/1728/1767/1782/1784/1797) FLASH
Identification
Entering reprogramming mode
Passing Security Checks
Transfering Bootloader
Verification
Serial number: 41800208-13E08115-75080010-1118F800
Hardware: 00001820-00009101 0053C001-0055C001
ECU: TC1797 rev. 1
Protection 1: RW W0 [00000-1FFFFF] OTP [10000-17FFF]
Protection 2: RW W0 [00000-1FFFFF]
Completed
Thanks in advance, any help and guidance is much appreciated!
Below is my setup:
Identification
SW Version: 0020
VIN:
Reprog count: 0
ECU: ???
Completed
Identification
Verification
ECU: TC1797 rev. 1
Completed
