Help me, i need driver 64 bit china mongoose
Help me, i need driver 64 bit china mongoose jlr 3 in 1 for toyota techstream,
windows 7
thanks you
(01-17-2019, 07:42 AM)fajarse Wrote: Help me, i need driver 64 bit china mongoose jlr 3 in 1 for toyota techstream,
windows 7
thanks you
Hi.
I have uploaded the very last drivers released by the original manufacturer for the mongoose jlr pro to mega.
the chinese clone mongoose jlr pro is the same as the original mongoose jlr pro version 1 cable.
in the zip file you will find 32bit as well as 64 bit drivers, the driver setup file has to be used in order to install them.
the setup file not only contains the drivers but also the very last firmware for the cable as well, the firmware fixes a couple of bugs with the interface.
my question to you is why do you want to try this cable with the toyota techstream software.
the manufacturer, drew technologies, that makes the mongoose pro has a specific interface cable for toyota which uses slightly different internal circuitry and is specifically for the techstream software.
the drivers for all their interface cables can be downloaded from their support site with the exception of the drivers i have uploaded for the original version 1 mongoose jlr pro cable as they do not want to assist the chinese clone manufacturers.
.zip
mongoose jlr drivers.zip
114
216 bytes
Thanks given by: hasse , Alioth , fajarse , rainbows528 , carpi , dinho , CheMax
I'm looking for a mini vci replacement, because the mini vci doesn't support the datalist from the 2GD machine and the otc is too expensive for me
07-05-2020, 06:12 PM
05-27-2020, 05:16 PM
04-13-2020, 11:23 AM
