Help with sid803a does not start
Hi guys, yesterday I read a c5 2.0 rhr sid 803a to egr off by obd, the reading was correct, but when the file is written in the middle of the writing it is removed and the writing and the auto does not start.
Give me the dtc
U1118
P1693
U2001
How can i fix this?
nobody can help me?
id.
HW: 9655534080
SW: 9663008280
Num.VIN:
Ver.SW:
Recambio:
Motor:
Ver.HW:
SW act.: 9663008280
Instalación:
Hi! Try to write again the ori file.
witch tool you used for read write , can you post files ori and mapped here will see
you must recovery ecu
wich tool you use for read/write?
If i helped you press thanks + rep Handshake
try to write by obd file again.
if not work you have to recover ecu by bdm
Thanks and Rep are appreciated if i helped
06-10-2026, 11:29 PM
06-03-2026, 05:51 PM
06-01-2026, 10:02 PM
