How check if the PD injectors are in good condition
10-12-2017, 11:47 AM
AA Bosch-logo How check if the PD injectors are in good condition
Good evening, someone knows how to check if the PD injectors are in good condition ??? by VCDS ??? how to do this procedure in the most reliable way possible? NerdNerdNerd
(Engine is 2.0 TDI 8V Motor Code: BRT)
Thank you
10-12-2017, 01:07 PM
RE: How check if the PD injectors are in good condition
(10-12-2017 11:47 AM)DCautosport Wrote:  Good evening, someone knows how to check if the PD injectors are in good condition ??? by VCDS ??? how to do this procedure in the most reliable way possible? NerdNerdNerd
Thank you
Most reliable is let them test on bench...
Please use [Image: postbit_thx.gif] and [Image: postbit_reputation.gif] if I helped you!
 Thanks given by: DCautosport
10-12-2017, 01:22 PM
VCDS channel 13,23 or test on bench.
Pc
10-12-2017, 01:56 PM
ok and what values should I interpret in these fields in vcds?
until values are good?
10-13-2017, 04:18 AM
If I'm right any think above 1.5 is wear 3.0 is bad these figures can be +or - , but this value your looking at it how much the cylinder is being balanced out so doesn't always mean bad injectors can mean worn bores ect , but in most cases it is injectors , always worth doing a compression check as if one is low that will give you a high figure
 Thanks given by: DCautosport , familyman
10-14-2017, 10:19 AM
I opened the engine and got cracked pistons. I look for the cause of it, I think it will be injectors. but in my country whenever the PD injectors are going to do a bench test .... Never but never they are good ... they are always damaged. the other day in a coffee break, we were 13 mechanics, and we talked about it, never but never are the injectors within the parameters. unfortunately we are a small country and PD injectors few shops do the test, and as they know that there is no way to counteract that they say they are spoiled. We come to the conclusion that even if they are good, they say they are not to win the repair.
in this conversation, a mechanic claims that, they did repair 4 PD injectors in the bosch, he received the injectors repaired .... a week later sent those same injectors to the same bosch to test on the bench .... the test stated that all they were out of order, and needed to be repaired ...
he did complain and gave 4 injectors new .. but always denied that they say they are always damaged ...
But it's easy to come to this conclusion ...
In my country few are mechanical believe in bench tests for PD injectors ... the vast majority do not believe ...
10-19-2017, 03:01 AM
PD repair is nothing for tree mechanics....
big database CR injector parameters + dieselpump (line + rotary) adjustment data. also can help with crosscheck nozzle codes / size
10-19-2017, 06:43 AM
(10-19-2017 03:01 AM)DieselSandraSTD Wrote:  PD repair is nothing for tree mechanics....
I did not realize what you meant by that !? 533
10-19-2017, 07:48 AM
VW RE: How check if the PD injectors are in good condition
Hello
Maybe this can help
https://sites.google.com/site/1810martin...wPrintD…
https://sites.google.com/site/1810martin/
=> VCDS AND PD TDI ENGINE HEALTH CHECK
=> INTERPRETING B6 ENGINE DATA LOG
Best Regards
Audi Seat belt Internal Control Module Memory Check Sum Error dwilcox 2 950 09-17-2018 12:03 PM
Last Post: dwilcox
Audi Audi s3 8p 265hp map is good or not Aygo 1 79 07-16-2018 10:09 AM
Last Post: Mis32
  VW T5 2.5TDI AXE putting injectors from 1.9 shewush 0 42 07-04-2018 09:25 PM
Last Post: shewush
VW file check caddy doey 0 62 06-19-2018 08:08 AM
Last Post: doey
Audi Audi A4 history check nikinike 4 81 06-18-2018 06:26 PM
Last Post: nikinike
