  • 26 Vote(s) - 3.31 Average
How to enable offline programming das xdos 05/2015
Hello, please can anyone help me on how to enable offline programming on windows 7 32bit das xdos version 05/2015?
Thanks alot
You sure do ask for a lot of help before searching...
http://mhhauto.com/Thread-Xentry-OpenShe...links-HERE
Thanks given by: kamaleon , gazchab
http://mhhauto.com/Thread-DAS-PKW-SMART-...nd-updated
Tested! Perfect work!
FULL DATABASE of MB FLASH FILES CFF SMR-F
MB FACTORY SOLUTIONS
Thanks given by: gazchab
yes i tried it but i get the following errors
any help please
thank you
Maybe you miss some steps. On my system all working fine
all the steps are done 100 % please advise
(01-09-2017, 02:38 PM)ghassan.chaabo Wrote: all the steps are done 100 % please advise
OK. If you have problems with offline programming then you can flash ecu by vediamo. If you haven't cff file for it I can give you file for any ecu where flashing is possible.
(01-09-2017, 02:03 PM)ghassan.chaabo Wrote: yes i tried it but i get the following errors
any help please
thank you
i think pesona has prepared the files at first page.
u have to put the etn files to the correct folder. *The third picture*
and also the flash files iinm...
i solved it by copying the pkw files from an old version that was working, thank you soooo much
Thanks given by: alexjx
