getting ready to a camera retrofit on 2007 w221, I have been told that I can enable rear view camera in das/vediamo and just run video signal to pins 7,17 on back of comand from camera without the need for any extra module. my question is, where in das do I enable rear camera option? is it listed under rear sam? I also have vediamo, but not sure how I would code for that. I have xentry/das version 03/2013 with developer key and offline patch, and I have 09/2016. I'm sure I would have to do it with the older version. any input or tips?
[email protected]
How to enable rear view camera w221
10-07-2016, 04:11 PM
In Xentry go to
control units,
Information and Communication
Audio Video Nav.,
under "MOST components" select command
select Retrofitting of telematic special; equipment
F4 for backup camera
follow instructions
I did a similar procedure on a 211 and it worked great.
control units,
Audio Video Nav.,
follow instructions
Thanks given by: marvelouzone , KriyenKPp , Rayman123
10-07-2016, 06:55 PM
(10-07-2016, 04:11 PM)Peter6000 Wrote: In Xentry go to
control units,
Audio Video Nav.,
follow instructions
ok, i'll try that, but for some reason under that option, I dont remember seeing the retrofitting option, i'll be checking in a few hours though. thanks
