I NEED TO DELETE DTC P-2359 MB 280 CDI
HELLO.
I HAVE SENT MAP TO DELETE DTC P 2359 TO VARIOUS PROFESSIONALS. AND THEY HAVE NOT HAD SUCCESS.
THE DTC WILL APPEAR AGAIN.
IT WOULD BE GRATEFUL IF ANYONE CAN DELETE AND DO NOT APPEAR MORE THAN THE DTC.
THANKS
MB2786FTCORI.rar
55.97 KB
(06-29-2019, 02:55 PM)XAPPO Wrote: HELLO.
THANKS
The problem is ecu have double dtc table
if you not attach BDM read, nothing solution will work
Chiptuning DynoTested
File services - DPF/EGR/DTC Exc
PCR2.1 Full Clone - Edc17 Full clone
/t.me/Edc17tricore
THANKS
2359=there are two(-1) and (-2) either is a high or low charge pressure.
you either have a leak or you have a faulty turbo
positioner!with delete Pcode not mean car runs ok in case faulty turbo
positioner.
ECU-REPAIR-KEYS-IMMO-ABRITES FULL MERCEDES-ALFA-PSA  GROUP-VW-ORIGINAL XPROG-UPA ENIGMA-MANY OTHER
Every days a schoolday
hello.
the problem is 150 mbar lower pressure, I'll try bdm.
thanks.
Sure your car have automatic gear.
MB edc16c32 have 2 map table, if you have automatic gear, ecu use all map table, if you have manual gear, ecu use only second map table.
Throught OBD you can only read second map table.
If you want to tune or disable dtc on MB with automatic gear you must read ecu in BDM.
But pay attention, don't try to open ecu, otherwise you destroy it, you must cut the back cover.
06-07-2026, 01:58 AM
