  • 1 Vote(s) - 3 Average
Info on Qashkai start-stop
Hi, what is proper way to completely disable start-stop on Nissan Qashkai J11 1.6 with sid309? If it is possible...
I was researching but i am not sure. Is it possible with dd4all like Renaults? Can it code out from dash?
If i am correct disabling from sid309 flash gives dash error?
Please any info from someone who did this would be would be appreciated.
(08-21-2023, 06:38 PM)dtip Wrote: Hi, what is proper way to completely disable start-stop on Nissan Qashkai J11 1.6 with sid309? If it is possible...
The proper and way to do this is going the injection ecu to start&stop diagnose mode, help by renolink/ddt44all/ddt2000
Nobody will notice  that, the cleanest method , picture attached for you. Guaranteed no errors displayed as long as it is a way to diagnose problems the factory conceived that.
[attachment=556705]
Thanks given by: dtip
tnx mate, i will try that, car not here so i can't experiment. But i heard that on nissan it is going to give dash error and on renault/dacia is all ok.
Also will it work when there are errors on S&S system ?
I don't have much experience on renault based coding but i have renolink and there is no that option when chose any of SID309xxxxxxx.xml ... It is on sid310  only, will it work anyway on 309 as well?
(08-22-2023, 08:29 PM)dtip Wrote: I don't have much experience on renault based coding but i have renolink and there is no that option when chose any of SID309xxxxxxx.xml ... It is on sid310  only, will it work anyway on 309 as well?
try this xml file, 2018 file, this should work for you, attached here :
SID309_00FA_600_V01_20140313T130942.xml
[attachment=556947]
Wanted to update this thread and if anyone have any idea to try to disable this shXX .
I tried this solution with renolink and it puts S&S in service mode but it does not change nothing regard instrument cluster error (see photo).
What i noticed in renolink that it always shows driver absent, marked in second photo.
No other errors on diag or on instrument cluster. Everything else works as it should.
You can disable with consult, with no warning messages after. i have done it, sometimes problem with start&stop on those are one sloppy connector on relay inside fender left side, also sometimes big relay behind battery has loose connector on plus cable!!
(10-27-2023, 02:23 AM)doey Wrote: You can disable with consult, with no warning messages after. i have done it, sometimes problem with start&stop on those are one sloppy connector on relay inside fender left side, also sometimes big relay behind battery has loose connector on plus cable!!
ok i will acquire consult tomorrow just for this job. can you please tell me procedure for disabling as i never used nissan consult?
i still can't find solution for this. Now i have read ecu flash sid309 to see if screen message is maybe from bad egr or dpf off?
if someone can check if file is modified, i can't find this SW online:
HW: 23710411R4
SW: 237014EA5D
