Initialization of the multiplexer failed - XENTRY
Hello guys, I'm facing this problem since I've uninstalled 24.03 xentry and tried to install 2025.06, then 2026.09 and then 2024.03 again, but I'm facing same and same problem. I've tried everything possible, in my opinion of course, since I'm not doing something correctly..
I'll appreciate your help !  USING SDConnect star C4 clone, which was working perfectly before uninstalling xentry
Error message :
com.teradyne.ds.gradex.asam3d.Asam3dVciNotAvailableException: VCI is not available
  at intern/prepareInterface%20-%20Task/NODE16
  in file:/C:/Program%20Files%20(x86)/Mercedes-Benz/Xentry/Kontexte/Allgemeine_Ablaeufe/Fahrzeug-Kommunikation/Asam.gmf
(10-05-2026, 03:23 PM)gurovv Wrote: Hello guys, I'm facing this problem since I've uninstalled 24.03 xentry and tried to install 2025.06, then 2026.09 and then 2024.03 again, but I'm facing same and same problem. I've tried everything possible, in my opinion of course, since I'm not doing something correctly..
Error message :
Hi, did you configurated the sd connect and Lan ip correct? Make sure Lan ip adress and sd connect ip adres are in the same range.   eg: Pc lan adres IPv4 = 172.29.127.200 and sd connect = 172.29.127.129
If I helped you please push thanks or/and rate
Most likely you need to fix your xentry for sd c4.
DTS Monaco 9.04.016 all smrd working LIC Truck actuation, W206 Certificate, Xentry Ecom
(10-05-2026, 04:22 PM)i860 Wrote: Most likely you need to fix your xentry for sd c4.
in what way buddy?
To prepare xentry for sd c4.
